 Romaq
Date sent: 2015/08/14 07:47:19
http://webbcraft.co.uk/contact.php is broken. Please fix or remove references to it as appropriate. |
Date sent: 2015/08/15 07:17:50
I fixed the page, but it might not send the contact form reliably. |
Date sent: 2015/08/15 07:18:47
I see, is it a bit different then the last one?
I like the layout :3 |
 Romaq
Date sent: 2015/08/15 13:22:42
As you said in the page that comes back after using it:
Thank you for contacting us, we will get back to you as soon as possible via email.
NOTE: Sometimes this contact form does not work. It is not a reliable method of contact.
If it is not a reliable form of contact, the email which you use (or "staff@webbcraft.co.uk" would be more appropriate than a form that doesn't work "reliably". A contact form that may or may not work (and clearly says so) is hardly professional. What would be the point of using it? |
