creative restrictions removed? pls respond luigi.
Date sent: 2015/08/17 05:52:26
Ok, so i got on today and i was already in creative mode from last time i was on. I went into survival to do some mining and my inventory stayed the same!
I talked to JameSkullBlood, and he said it had been happening since you, luigi apparently used console to do a server restart.
I also just now talked to Blueroon, and he says it was likely you removing the plugin that restricted creative mode. However, I cannot place the valuable blocks still, but if I put them in my inventory and go to survival and they are still there. Does this mean you removed the plugin, or is it a loophole created during the restart somehow? Also, if this a loophole, and you fix it, will our survival mode inventories be restored, or not?
Please respond, luigi, so us donators know whether or not we can use this. If it is indeed a loophole please fix as soon as you have time, as im sure lots of people have used already.
Thank you.
Date sent: 2015/08/17 08:21:39
The server seemed to be crashing presumably because of that plugin so I removed it to see how things went. Yes it is a loophole that is not to be abused and your survival inventory is still stored in the plugin data so when it is fixed they will be restored.
Date sent: 2015/08/17 19:44:47
thank you luigi
