CloudyBogdan |
Date sent: 2015/11/29 22:14:02
Hey GUYS! Some of you may know that some people suggested to install this plugin that allows you to chop down a tree with one shot and it works 100% properly. This will reduce time of work also will still reduce the appropriate amount of hunger and durability as you would chop the tree down block by block, so here's a little video I made so maybe Luigi could add this plugin to Webbcraft. Enjoy: https://www.youtube.com/watch?v=Lx9tdWgTXhk |
Wowman2002 |
Date sent: 2015/11/30 13:44:08
So many people have suggested this. |
dublindevil. |
Date sent: 2015/11/30 14:44:17
What texture pack is that? |
CloudyBogdan |
Date sent: 2015/11/30 17:57:40
@dublindevil It's called Faithful |
Wowman2002 |
Date sent: 2015/11/30 20:58:50
I have that one. |
Harveyc1 |
Date sent: 2015/12/01 05:35:19
IF you cant Disable it then -1 and if you can then +1, because What if People LIKE Cutting Trees down one By One? Think about it. xD |
CloudyBogdan |
Date sent: 2015/12/01 06:19:30
Yes you can disable it, it useful though and people will never like to chop a portion of a tree |
Guiness4 |
Date sent: 2015/12/01 19:10:44
Bogdan this is just one dumb plugin.. If you get MCMMO as a whole plugin, this sort of thing comes within that plugin. |
Dubz |
Date sent: 2015/12/05 07:38:32
+1 for the TreeCapitator plugin. It would save much needed time and help noobs get started. |
cptjacksparrow42 |
Date sent: 2015/12/07 01:42:33
-1. Some people have problems installing mods due to the operating system they use. For example, two of my friends use Ubuntu and have been trying and failing to install mods for around half a year. |
spacechicken27 |
Date sent: 2015/12/12 01:37:49
I think that it would be smart to have like maybe default (maybe citizen) not be able to use the treeassist. but definitely citizen+ and higher be able to use it.+1 |
Gavin |
Date sent: 2015/12/16 02:55:29
YES ADD THAT IT WOUDL,HELP SO MUCH IN CLEARING LAND AND SAY YOU NEED TOCLEAR JUNGLE BUT WANT THE WOOD INSTEAD OF SPENDING HOURS ON IT JSUT TAKE ONE BLOCKOUT OF EACH TREE AND YOU GET TONS OF WOOD NO MORE BURBPNING DOWN TREES |
Gavin |
Date sent: 2015/12/16 02:56:10
No fuck no not the only donator crap again I think everyone should be able to use this |
Gavin |
Date sent: 2015/12/16 02:57:58
I think everyone should be able to use tree assist or is it to op and the wood that is chopped by this plugin can not be given out or sold because it is not legit?? |
Pepperpot9 |
Date sent: 2015/12/16 12:16:07
It's not a mod... |
Chip_Bruh |
Date sent: 2015/12/16 16:23:16
it is available in mod form and plugin form pepper. |
miketikel7 |
Date sent: 2015/12/17 17:47:54
+1, this will be very useful because just to get 2 stacks of wood, I need to spend 15 min of doing that instead of building a cool house. |
Gavin |
Date sent: 2016/01/13 05:32:13
+1 add it |
Simpson15 |
Date sent: 2016/10/11 04:18:06
+1,000,000 please add this! |
Vulturboy |
Date sent: 2016/10/11 12:56:38
+1And no, it uses the same amount of durability. It just lets you cut down the tree faster. |
SneakySquirtle |
Date sent: 2016/10/11 13:50:01
If it isn't necessary then it will take up ram for something that is useful and Needed |
CloudyBogdan |
Date sent: 2016/10/11 14:52:52
Holy damn, that's an old one |
Simpson15 |
Date sent: 2016/10/11 20:05:35
yeah but it all adds upto making the server better so it is necessary in a way |
IAmSavannah |
Date sent: 2016/10/13 03:02:10
+1 all the way |
Ivy |
Date sent: 2016/10/13 08:03:43
thomasjones |
Date sent: 2016/10/14 16:26:06
-1 Takes away from the vanilla experience |
Xario1 |
Date sent: 2016/10/14 20:31:36
+1 Saves time |
ckvoss |
Date sent: 2016/10/15 17:27:29
-1 What Tom said. People have already suggested plugins like this one many, many times. It takes a lot of survival out. Like Gavin said: HELP SO MUCH IN CLEARING LAND AND SAY YOU NEED TOCLEAR JUNGLE BUT WANT THE WOOD INSTEAD OF SPENDING HOURS ON IT JSUT TAKE ONE BLOCKOUT OF EACH TREE AND YOU GET TONS OF WOOD You can take out a whole jungle in minutes. This also takes away any need of buying/selling wood. |
