CaptainSpaceSheep |
Date sent: 2016/04/14 08:51:46
I am going to kindly (unlike some of the other "suggestions") suggest that we have a map reset. Reasons to +1: the reasons to not -1Reasons to not -1: Fresh start. Equality. It I it sucks having to restart, but imagine the possibilities; a new base for you, your perfect land not taken because no one has seen it yet! |
Chip_Bruh |
Date sent: 2016/04/14 10:47:23
**EDIT**i was incorrect. |
Date sent: 2016/04/14 15:24:32
I'm probably going to make an ingame poll on the map reset to decide this since website polls are not as reliable. |
CaptainSpaceSheep |
Date sent: 2016/04/14 21:17:53
Yes, Luigi. I have a tablet, phone, laptop, mac, & PC which I use to check the forums, and I have figured that I can place different votes from each one. |
CloudyBogdan |
Date sent: 2016/04/16 00:20:42
-1 Ok, I'll be ready for the map reset.....Is it true that after the map reset, no one will have GMC? If so, ok. 1 month is ok I guess, I would just have to hold up the series leleleelelelelelel. I will be sad D: xD |
Harvey |
Date sent: 2016/04/16 09:35:42
Bogdan fricken stop |
CloudyBogdan |
Date sent: 2016/04/16 14:55:20
I won't LOL. It's my reaction. Still -1 For world reset |
Gilgamesh8 |
Date sent: 2016/04/16 20:15:53
So...here are my thoughts.Reasons not to reset: -I'm in survival and can't just restart without a lot of struggle, and I assume this applies to many others. -I'm still working on lots of builds, and I assume many others are too. -All people tired of their current situation have to do is blow up their bases or move. Easy. There's literally millions of kilometers of blocks out there. Our current explored territory is about 50 kilometers, with SO much unused land in between (averaged, I'm sure people have gone farther) Reasons to reset: -Moving out farther might lag the server more, meaning gameplay might get worse if people packed up and left their current bases. I'm not sure when this starts being a problem, so I'll let someone else address this. -A fresh start does put everyone on equal ground again. But then again...If this is so desired, why do people use creative at all? My conclusion: Let's not reset yet. For those who want to start fresh: give away all your items, get into survival, remove your set homes and start walking into the wilderness. You get what you want, a fresh start, and those not finished with their homes get what they want. |
stojan44 |
Date sent: 2016/04/16 20:34:04
^you're working on something? so what. A reset will happen either way. So why struggle to build something that will dissapear. |
Chip_Bruh |
Date sent: 2016/04/16 23:42:41
Big structures can be transferred into the new world for you to continue the build. |
stojan44 |
Date sent: 2016/04/17 07:27:59
Oh. I had [i][u]NO[/u][/i] idea |
Date sent: 2016/04/17 13:22:31
Also the further out people go the larger the map file size gets and disk space usage becomes an issue. |
stojan44 |
Date sent: 2016/04/18 17:06:06
Im guessing that the host PC has one of those shitty seagate 250GB HDD'S amirite? |
Date sent: 2016/04/19 03:25:15
Firstly it's not a PC and it has a 120GB or 240GB SSD I believe. |
stojan44 |
Date sent: 2016/04/19 16:40:50
120 or 240? Livin' in 2007 i see. |
CaptainSpaceSheep |
Date sent: 2016/04/20 05:36:37
Stojan, since your so concerned please go by a 1TB SSD for the server ;) |
stojan44 |
Date sent: 2016/04/20 08:41:56
Wasting money on a server? No thanks. |
CaptainSpaceSheep |
Date sent: 2016/04/20 10:40:26
pls our "250gb Hard Drive Seagate model 54728:(:))" is broken I need helppp |
Harvey |
Date sent: 2016/04/20 13:05:39
Luigi if you do reset the map. Can EVERYONE be survival. Not even staff as that just means more people will just want the rank because of creative. Also it would makes it unfair |
stojan44 |
Date sent: 2016/04/21 12:46:01
Captain if it was broken,i'd be glad. Anyways Harvey that sounds like a great idea. |
CaptainSpaceSheep |
Date sent: 2016/04/22 06:10:56
Harvey let me explain why we can't do that; -EULA Terms & Conditions. People payed for their rank and it is under Mojang's EULA Terms that it cannot be taken away, atleast without a refund. In the servers time, it has probably raised more than1000 dollars. About 200 is put into the server each year. It would be very difficult to refund every single donation. |
stojan44 |
Date sent: 2016/04/22 06:26:12
Captain,Not perma taken away. Just for a certain period of time. A week maybe. |
CaptainSpaceSheep |
Date sent: 2016/04/22 22:26:35
In that case, creative is usually restricted for a month. With the most recent reset it was. |
XxDJAssasinxX |
Date sent: 2016/06/06 06:27:06
OMFG!!!!!!!!! I HAVE THE BEST IDEA EVER GUYS!!!!! listen kkthere should be 2 servers. old survival and regular survival old is the old survival world. new is the resetted version. u can pull out your won structuers from old survival to regular. gud idea yeah? |
