 Frank1900
Date sent: 2016/05/01 13:56:36
Hey Guys. i just joined the server yesterday and everthing was ok. After playing for an hour or so i decided to have a good look spawn. i found the spawn town and went for a walk when i was suddenly disconected wth the error"Internal Exception: java.io.IOException: an existing connection was forcibly closed by the remote host " i then treid to join again i could join but i couldnt speak (everone was saying wb and i tried to say hey) then after a minute or two i was disconnected again. after serveral times of joining and being disconnected i just gave up i tried a few times today but it says the same error but sometimes it just says diconnected. so im just asking to see if you's know what i should do. hope we can figure this out! Thanks! |
Date sent: 2016/05/01 14:20:12
The error message itself means "you have disconnected due to lag". So it's not actually giving any info that will help me (or luigi) fix your issue.
As the for the talking in chat issue, press escape and go into options > chat options and enable chat. This should fix the talking issue, if it doesn't then please let a staff member know by using the command /me <message> or /helpop <message>, or of course you can notify us on here. |
 Frank1900
Date sent: 2016/05/01 14:22:05
Thanks will try this
 JamesSkullBlood
Date sent: 2016/05/01 16:13:26
Frank try to get on minechat then try to get on PC as it will reset you to spawn and not in that area of where you crashed. |
