ckvoss |
Date sent: 2016/07/03 20:58:52
Hello, I would like you to add RTP (Random Teleport) plugin. It is better then just being teleported to the same spot with /warp wilderness. All the players do is /rtp and they teleport to a random place. |
thomasjones |
Date sent: 2016/07/03 21:03:11
CaptainSpaceSheep |
Date sent: 2016/07/03 21:07:57
+1.I've always wanted this plugin but never knew the name of it. |
Chip_Bruh |
Date sent: 2016/07/03 23:09:52
No need for this Plugin, it can be done with a command block |
Drago2144 |
Date sent: 2016/07/04 02:30:49
Chip,why don't we implement it?I mean,the current wilderness isnt even wild.. |
Ivy |
Date sent: 2016/07/04 15:31:26
Chip_Bruh |
Date sent: 2016/07/05 11:58:33
I have done some research into this using command blocks; Here is a video of me using the random Teleport in the old world:https://youtu.be/4R2f8BbXi88 The max radius that you are tp'd away can be much larger than what i have set up in the video (1000 blocks away from the command block), but as you can see, i am tp'd to a completely random co-ordinate each time :D Over time when the radius of this random teleport is beginning to get crowded, an OP can easily just make the radius larger. The message that i get after the teleport wont show up for any players, it will just teleport them, looking professional ;D Anyway yeah i see no reason to not have this feature at spawn, i think it is an amazing alternative to /warp wilderness. We're just waiting on luigi's go-ahead and for me to have temporary access to creative so that it is possible to use the command block. |
ckvoss |
Date sent: 2016/07/05 23:54:14
Yes, but you see, its easier to just have a command instead of a button. |
Chip_Bruh |
Date sent: 2016/07/06 00:37:48
It may be easier, but just because you don't have to go to spawn and click a button instead of typing a command, it doesn't mean that its a good excuse to implement the plugin.Too many plugins cause lag, using a command block will work just fine. we should work with what we have got until we NEED to add something to the ingredients. By using the command block instead, we have much more control over the limitations of where the players can go and how often they can use the command - eliminating the fear of it being abused. looking from the view of someone wishing to prolong the excitement and adventurous side of the server; making it harder to use the 'Random Teleport' successively will increase the want for players to walk and adventure through the map, coming across all sorts of amazing Minecraft features; in turn making the server more enjoyable to play on. |
Wolves_rock5651 |
Date sent: 2016/07/07 05:46:03
But that could possibly inconvenience players making go back and forth like that :I.+1 to ckvoss's idea |
Chip_Bruh |
Date sent: 2016/07/07 11:26:20
that's the point Alyse... it's meant to be an inconvenience for players to have to go to spawn and press the button again; it's to deter players from spamming the random teleport and discovering the map faster than /warp wilderness where you have to walk. --> making the map last longer. |
madzahttr |
Date sent: 2016/07/09 01:05:45
Chip ur outvoted :P |
thomasjones |
Date sent: 2016/07/09 13:52:36
+1 for Chips Idea |
PumpkinPiePhD |
Date sent: 2016/07/15 16:54:10
+1 For Chips idea. I agree that a plugin for this would not be wise because it can be done with a command block. I do not know how the spreadplayers command works, but you may want to test it a few times to make sure it will not teleport you inside of the ground and suffocate you. Other than that it seems like a great idea. |
Drago2144 |
Date sent: 2016/07/15 22:44:46
As far as i know,plugins shouldnt teleport you into the ground.As for cmd blocks,Im not sure. |
Chip_Bruh |
Date sent: 2016/07/16 09:31:00
The spreadplayers command used in the command block is obviously a minecraft vanilla feature, and therefor any bugs that it may have came with (like teleporting you into the ground) will have been patched when it came out in 1.7... I think it came out in 1.7... The spreadplayers command is used in hundreds of hunger games maps, if there was an issue with it, it would have been reported and fixed my now anyway. You might be teleported on top of a tree sometimes, but does that really matter? |
stojan44 |
Date sent: 2016/07/17 18:09:18
S P L**admin: removed 108468 instances of "<br />"** **admin: removed 206 instances of "P LS"** |
thomasjones |
Date sent: 2016/07/17 18:34:40
This idea has now been implemented by Chip. You can find it at spawn |
Chip_Bruh |
Date sent: 2016/10/20 21:15:46
I've implemented the command block on the new map. |
DreemurrTheDreamer |
Date sent: 2016/10/20 22:22:11
gg. now people have a chance to randomly teleport to my house. |
Vulturboy |
Date sent: 2016/10/21 03:33:38
^And you wonder why people don't like you |
Date sent: 2016/10/21 05:34:09
what the hell did i do???? |
Chip_Bruh |
Date sent: 2016/10/21 20:35:33
Dreemurr, your house is about 7k away from spawn (way too far), and the limit on the random tp is 750 blocks from spawn. |
madzahttr |
Date sent: 2016/10/22 06:02:46
the rtp plugins has a command command blocks don't plz add rtp plugin |
Chip_Bruh |
Date sent: 2017/07/23 12:31:12
I've expanded the random teleport |
Presinus |
Date sent: 2017/07/23 15:40:34
Similar to what Dreemurr mentioned, could this teleport people to any of my hidden bases? Even if it's a 1 in 24,000^2 chance, I don't want that happening. |
Date sent: 2017/07/23 18:00:23
What has it been expanded to? 1000 blocks away? |
Chip_Bruh |
Date sent: 2017/07/23 21:21:51
yes presinus. it shouldn't matter too much anyway because the base should be claimed and the player will highly likely only be searching for clean land to build on. Not to mention that if you want a secret base, you shouldn't be making it near spawn xDi did it to 1k luigi, but the random TP had been on 750 for so long that 1k blocks away didn't TP me to any clean land every time i used it. the TP is set to 1250. |
Aouldrain |
Date sent: 2017/07/23 22:14:08
it should be expanded by 100 every month, or something? idfk |
Presinus |
Date sent: 2017/07/24 03:03:46
I used the random teleport button today and it brought me to someone's hidden base on the third try. My suspicion has been confirmed. |
Chip_Bruh |
Date sent: 2017/07/24 07:55:20
How do you know its a 'hidden' base? |
Presinus |
Date sent: 2017/07/25 03:51:04
'Cause it took me a while to find it. |
Chip_Bruh |
Date sent: 2017/07/25 08:27:34
"third try"Using the random tp 3 times would probably take me about 25 seconds, unless of course you mean you weren't actually tp'd into the base, and you took the time to actually search for it. In which case completely invalidates your argument. |
Presinus |
Date sent: 2017/07/26 05:30:33
*It took me a while to find the way out. Getting out was was easy, but to get in there was a Jeb door with a hidden button, which led to a natural-looking cave, which led to a ravine, which led to another natural-looking cave, which split repeatedly on the way, which led to another Jeb door, which led to the base. The random warp put me in the ravine, where the first set of pistons were visible. I had to poke around for a very long time before I found the other Jeb door. |
Chip_Bruh |
Date sent: 2017/07/27 23:03:31
What you just described to me was you searching for the base. Not the random tp taking you inside the base 😂😂 Fuck off lmao |
Presinus |
Date sent: 2017/07/28 02:28:08
Fuck on. If it would have tped me 50 blocks further, I would have been in the base. |
Zedcall |
Date sent: 2017/07/28 19:28:06
Presinus stop trying to pick a fight with everyone over the forums. |
Presinus |
Date sent: 2017/07/29 01:30:02
So I'm the only one to blame for arguments, right? |
