Remove /butcher from staff members
Date sent: 2017/03/18 16:27:13
I see no point in having access to /butcher. Only head admin and the owner should have access to it. Recently another person used /butcher which resulted in the death of my 300 chickens (The ones which I had to replace the last time someone used /butcher) and all my 30 whitecoats, 2 of which were mending villagers, along with Thorns III, aqua affinity, Power V, and sharpness IV. Alot of other people have also had issues with idiotic staff members using /butcher. this also affects other people who were not doing anything bad.
Date sent: 2017/03/18 16:32:44
Date sent: 2017/03/18 16:49:50
Butcher is used for is someone has hundreds of thousands of mob and they are lagging the whole server. That is the only time it is (and should be) used.
IAmSavannah
Date sent: 2017/03/18 18:02:54
I also lost my chickens that were being used for my chicken farm and have yet to find a staff to replace them.
Date sent: 2017/03/18 18:34:55
You shouldn't have a chicken farm with 300 chickens. That's way too many, spawning excessive amounts of entities is against the rules. It is absolutely essential that staff have /killall in order to reduce lag.
Beetley
Date sent: 2017/03/18 20:06:41
Three hundred MineCraft chickens?
Sounds tragic. I'm sorry for your loss.
Date sent: 2017/03/18 20:12:09
luigi, that's besides the point. The point is that other people are also affected. My whitecoats don't cause lag, they were killed. And I don't think that I'll be expecting a replacement either.
Date sent: 2017/03/18 21:27:52
"The point is that other people are also affected."
If that was true then you would have mentioned that in the actual complaint. You're just saying that so that you have a half decent response to luigi.
Had to call you out on that, soz.
Date sent: 2017/03/18 21:31:13
welp the actual complaint has been edited now, thnx for reminding me <3
Date sent: 2017/03/19 05:09:47
Yes, if some people had a small amount of chickens that were also removed in an attempt to clear lag, it negatively affects them. The server lagging also negatively affects everyone. Both of these are the result of irresponsible people spawning excessive amounts of entities. That's why it's against the rules.
Staff attempt to remedy the lag by using /killall on an entity type, and attempt to remedy innocent players losing entities by spawning them back in for them.
Techy
Date sent: 2017/03/19 08:29:19
Why not just use "/kill @e[r=<radius>,type=<entity>]"?
Asriel๐Ÿ†
Date sent: 2017/03/19 10:31:10
^ fucking brilliant man right here
Date sent: 2017/03/19 11:27:11
Because /kill doesn't work.
Techy
Date sent: 2017/03/19 12:23:17
/kill is vanilla minecraft. Why shouldn't it work?
Date sent: 2017/03/19 20:47:12
I swear that galbby is on a quest to get everyones commands removed ๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚
Date sent: 2017/03/19 21:20:25
Tom hush๐Ÿค“
IAmSavannah
Date sent: 2017/03/20 00:40:36
And Luigi, I only had about 20-30 chickens in my farm yet I lost them due to the /butcher. And when I asked staff to roll them back, I got ignored. That's what pisses me off more than the fact that people have /butcher in the first place. I ended up having to get eggs from another player so I could attempt to fix the issue myself. It's just 20-30 chickens but damn the least staff could've done is help get them back.
21leke
Date sent: 2017/03/21 02:26:30
Next your gonna want /back removed
