Minigame Suggestions Go Here
Date sent: 2017/04/14 22:00:35
If you would like a mini-game to be created, leave a comment here deeply explaining the rules and concepts, and I (With the help of Chad) will create the mini-game if people seem interested in it. When creating an idea for a mini-game, please give it a name for people to reply to you.
If you are voting on a mini-game, do
<Minigame name>: +1/-1
OfficalMinoi
Date sent: 2017/04/16 14:13:55
Mini Game: Sharks and Minows:
Basically, there is two sides, and one person standing in the middle with armour and a sword, the goal is for the minows to run across without dying. The shark in the middle has to try to kill all the minows while they run across to the other side and the minows goal is to get to the other side without dying. It goes until the last minow is left.
This my favorite minecraft game ive ever played
Date sent: 2017/04/16 18:45:02
Ah, not a suggestion, but I made TicTacToe. /Warp tictactoe or NicNacNoe.
Dragon
Date sent: 2017/04/20 14:46:49
There's a minigame called SkyFlag, it's a bit like skywars and capture the flag mixed. There are several islands, a middle (set with enchantment table and bookcases) each team's main base (with two sets of wooden 'logs'), on opposite corners, the two flags (red and blue) and on the other two corners, just normal islands, and on either side of middle there are another two (higher up) islands. Each player gets two health pots, a bow with 64 arrows, 64 steak, and an iron sword, 32 exp bottles and 16 lapiz (with iron armour and helmet of their teams colour). On the original minigame (which we will understandably not be able to re-create) it is 7 captures of the other players flag (which you cannot build directly next to or below) or a pathetic amount of each player dying, so obviously, this is an unrealistic goal, so I thought three deaths for each player and one capture of the flag. If all players are eliminated, then the opposite team wins, or, if one team captures the flag... Obviously, this would be difficult to create, due to mining down to bedrock and shizz, but it could be said that if they fall off one of the islands, then they are dead.
And I wrote an essay...
Date sent: 2017/04/20 20:45:19
Some people will already have xp though, dragon
Dragon
Date sent: 2017/04/21 21:13:26
I don't really know how to respond to that xD
Date sent: 2017/04/22 00:04:07
Maybe we kill everyone so they lose their xp? xD
Dragon
Date sent: 2017/04/22 14:14:17
Maybe
PumpkinPiePhD
Date sent: 2017/06/13 15:57:12
Or instead make xp banks. Ive seen them on YT before and they are made with a command block, when you stand on an enderchest it takes all of your xp and when you stand under it it gives it back. Require people to use this or alter the commands so that you can do it forcibly to those who want to participate.
TooeleJedi
Date sent: 2017/06/24 15:01:21
I have a minigame ck but if possible i would like to help make it. The minigame is called dogfight, so in the beginning all the players put everything they don't want lost away and then someone with gamemode gives them iron armour and iron sword and an elytra and a couple stacks of firework rockets, (everything that came from creative must be given back) then there are 8 towers put in a big circle, all the players must be on their elytra at all time once the game starts and players try to kill each other while on elytras, if you leave the arena you are out, if you land you are out, if you die you are out, last man standing wins. (yes it is possible to pvp on elytras, i've done it before)
TooeleJedi
Date sent: 2017/06/24 15:03:52
Minoi, for sharks and minows instead of the person trying to kill them (cause that would take multiple hits and in the irl game you just need to tag them) the shark could get a knockback stick that on the sides there is a lava moat, the shark hits them into the lava moat to kill them instead.
TooeleJedi
Date sent: 2017/06/24 15:04:16
^if you add what i said about sharks and minows ill +1 it otherwise -1.
TooeleJedi
Date sent: 2017/06/24 15:05:09
-1 for skyflag its too confusing and normal skywars sounds way better.
Date sent: 2017/07/06 07:38:05
Place a stone pressure plate on a gravel block on a TNT block. Now make a 50x50 floor of that. If you sprint, the ground behind you will fall. If you walk, the ground underneath you will fall. Add walls around that and 4 entrances. Last guy to fall wins.
Date sent: 2017/07/06 11:18:40
Very good idea Presinus!
i think im going to make that right away :D
Date sent: 2017/07/06 16:41:12
I'm pretty sure TNT run is hard to do unless if everyone has speed 2, you can't sprint without it falling beneath you anyways Presinus. I tried it on my old server a while back.
Date sent: 2017/07/06 20:23:54
you're wrong ck >:)
i've made the arena, it can be found at /warp TnTRun
Date sent: 2017/07/06 21:02:56
uhhh well it is a great idea, but it drops the server's tps..
took so long to build aswell :(
Date sent: 2017/07/09 04:55:17
I thought the game was my personal invention, then someone told me it already exists in Highpickle. Upset, I logged on to Highpickle. I played a round of Trinitrotoluene Run and it was SOOO boring in comparison to the one I came up with. No plugins needed.
Date sent: 2017/07/09 15:28:51
Yeah Presinus, it was invented a long time ago.
Date sent: 2017/07/10 06:06:27
