Date sent: 2017/10/19 02:14:57
If rollback has been causing issues, why would you ask a staff member to try and use rollback even more? It'll only make the problem worse. The safest way, especially if it's only a minor thing like a few blocks missing, is to fix it manually. I even say this regardless of whether rollback is causing problems or not: for minor grief, like creeper holes, if it's easily fixable by hand, don't take the risk of using rollback because if it's used incorrectly then it can cause much worse problems. |
