how to insert a picture to the forums
JellyJoe198
Date sent: 2018/06/02 01:33:43
step 1: find the image you want
step 2: right click the image and click "open image in new tab"
step 3: copy the address of the picture (control C)
step 4: click image above the text of your post and paste the link (control V)
example: Image
JellyJoe198
Date sent: 2018/06/02 01:34:53
when you click image it should show "Image" and you put the link between the 2 "[img]"'s
Date sent: 2018/06/02 03:49:12
You can skip step 3 if you right click and select "copy image address" instead in step 2.
wones9
Date sent: 2018/06/03 23:14:55
lemme try
Date sent: 2018/06/04 02:52:24
Testing 1 2 3
Date sent: 2018/06/04 07:05:33
Also, to resize an image you can add a value for width or height inside the img tag like this: [img width=500 height=1000]
To maintain the aspect ratio of the original image, omit one of the values like this:
[img width=500 height=] or [img width= height=1000]. It doesn't matter whether you specify width or height first, it should still work. You do have to specify both though, even if one is left blank.
Tye
Date sent: 2018/06/04 14:28:31
i cant read cursive
Platty2000 =3
Date sent: 2018/06/12 23:44:06
Grovemeister
Date sent: 2018/07/12 13:51:24
Test
Grovemeister
Date sent: 2018/07/12 13:51:41
YEA!
