Delete the Suggestions Section
Date sent: 2018/06/17 18:25:19
The Suggestions section of the forums serve only one purpose; to bring players false hope that their ideas and opinions have some sort of speckle of value or influence on the future of the server's conduct, so they stick around longer to see their dreams never come true.
The Suggestions section is worthless and no suggestions are ever encouraged unless Luigi doesn't actually have to put actual keypushes of effort into making it happen.
Delete the Suggestions section
Ranthar
Date sent: 2018/06/17 19:26:09
Date sent: 2018/06/17 21:39:06
legit +1
Date sent: 2018/06/18 01:53:57
deleting the suggestions section would require keypushes
Date sent: 2018/06/18 03:35:11
lmfao +1
Date sent: 2018/06/18 03:46:03
+420
Date sent: 2018/06/19 05:06:15
Maybe there should be a subcategory with all the accepted suggestions so you can see how many good suggestions have actually been implemented.
Date sent: 2018/06/19 06:44:31
+1 to luigi
Date sent: 2018/06/19 12:05:12
Maybe there should be a subcategory with all the shot-down suggestions so you can see how many good suggestions have actually been shot down.
Date sent: 2018/06/19 12:48:09
+1 to presinus
Date sent: 2018/06/19 21:17:17
+1 to presinus
Pheonix2000ad
Date sent: 2018/06/19 21:21:43
+1 to presinus
Tye
Date sent: 2018/06/20 01:42:33
quick question, can someone fill me in on how this would be beneficial, as im having trouble declaring a vote. i think the only problem is staff need to actually consider instead of shutting down, but i dont see an actually good reason to remove suggestions altogether.
Date sent: 2018/06/20 04:00:53
We do consider them. We Bring up the ones that we think we could implement to the other staff and we discuss them. We don’t always comment on a suggestion because half the time it’s already been suggested and that suggestion has been commented on with either reasons as to why we can or can’t implement it. I can’t say that for every suggestion as some are completely implausible.
Date sent: 2018/06/20 16:33:49
+1 to luigi
suggestions that arent accepted immediately have one of two reasons behind it.
One: there are problems with it that mean it cant be or shouldnt be implemented
Two: There are other things going on and we are busy, and by we i mean myself and luigi. In order to implement a plugin it isnt just install it and go,we have download it, run it separately from the server to ensure we have the latest version, make sure its compatible with the current plugins, if it isnt what do we need to disable to make it work, etc etc etc.
Date sent: 2018/06/21 22:23:16
update the fucking plugins
