Possible Spawn Ideas / Concept?? IDK
Tyranite
Date sent: 2018/07/25 14:45:21
To be honest I'm not sure how to upload an image on this so I'll just link my ideas via Imgur.
Just an idea; will be interesting to see what people think of them.
https://i.imgur.com/acaiq9y.png
https://i.imgur.com/LkC5z4s.png
Feedbacks appreciated. ;)
Pyrrhus
Date sent: 2018/07/25 16:19:10
Pyrrhus
Date sent: 2018/07/25 16:21:15
I feel like the roads are to big
It looks like the roads are 11 blocks wide so each section of road needs their own dedicated Chuck
Date sent: 2018/07/25 16:21:31
You people have to stop talking about ways spawn will be build. It's already in the process of being build. Hush.
Karbs
Date sent: 2018/07/25 16:41:38
I actually like the idea of having an organized spawn with designated areas for certain things. The map is actually really well put together, though in the screenshot you provided I feel like it would be best to use some sort of natural path and make it more narrow though. Hope this could be implemented when spawn is relocated.
MaxWreck
Date sent: 2018/07/25 16:54:36
@Aoul What are the coords for the in progress one ? I'd like to see it :P
There's a build team on it i believe ?
Tyranite
Date sent: 2018/07/25 16:59:27
Aouldrain, I knew someone was doing something with spawn; like I said it's just an idea. Not really sure what type of spawn your working on (what style/theme). Would be interesting to find out.
(Apologies for stepping on your toes a little; I was told if I want to suggest anything I should do it here.)
Pyrrhus, you're right the roads are quite big, I wasn't too sure of them myself but thought I'd see if someone else shared a similar opinion towards them.
(Also thank you for posting the images on here!)
Karbs, thanks; I think if it's more organised it could be easier to navigate around. I like the idea of narrow paths, just since I didn't know what style people are thinking for spawn then I chose one at random; since what I made is somewhat modern I think it would've looked odd with small paths instead or a road or something. But a compromise of something in between may work for this build style.
The map is designed to be expandable so as more players join more paths/roads can be added whilst still maintaining a somewhat organised appearance.
Date sent: 2018/07/29 18:45:51
In my opinion, modern city-themed spawns don't work well
Date sent: 2018/07/30 04:00:59
An ideal spawn is a small singular building that has a walkway that lets you view the rules, staff team, and further information if you want it, with a large vacant area outside of it for the whole community to build in. Shops, artwork, houses, whatever they want. And by the end of every map the community has created something special. I don't think it would be a good idea to make it this organized because I feel like a big part of spawn being so fun is how random it is!
Also @Aouldrain, just because you're building a spawn doesn't mean it's going to 100% be the new one without discussion. Players can still submit their own ideas, we'll pick the one we see as the most fitting.
