Forum Index > Ban Appeals > Ban Appeal > Read the topic
Ban Appeal
Jtank316
Date sent: 2018/07/28 02:06:09
Username: Jtank316
Reason for ban: X-ray?
When I was banned: this weekend
I would like to know why it says i have been using x-ray. I have been strip mining with the occasional turn because its not fun to mine in a straight line. If this is about the height changes its because I am trying to stay on
Y:8 that is where I have had the most luck but some times i get off of Y:8 and i dont realize for awhile. Please take this ban appeal into consideration I will respect your decision either way. (Thanks for you're time)
MaxWreck
Date sent: 2018/07/28 12:53:34
Hi JTank, last thursday, you mined 75 diamonds ore blocks in 2 hours, between 6h30 and 8h30. That would mean that you found between about 20 to 30 diamond veins in 2 hours, so you could've been lucky.
During that time, no strip mining was done. Your 1x2 tunnel has a few highly suspicious holes that led to diamonds. Also, the "occasional turns" were almost always right in a diamond vein OR led to another diamond vein.
I considered you as lucky for a while, but after looking at the whole piece of art, we came to a conclusion that this is in fact an X-Ray use.
As a second offense, the punishment could have been worse than a 2 months ban.
Jtank316
Date sent: 2018/07/28 13:20:28
can you put up pictures of the "whole piece of art"
MaxWreck
Date sent: 2018/07/30 21:34:16
Hey Jtank,
So i came back to investigate again (CCShad did as well), and now i truly believe that it was a mistake. There are some suspicious areas here and there, but this can happen to anyone who mines normally. I think that i focused more on the amount of diamonds in a short time, then tried to find evidences. I was not 100% objective on that and this will not happen again (hopefully...).
I apologize for that. You are now Unbanned.
Jtank316
Date sent: 2018/08/03 14:36:58
Thank you
Pheonix2000ad
Date sent: 2018/08/03 17:10:48
Max’s initiation complete.
MaxWreck
Date sent: 2018/08/04 04:15:53
First tempban, first fail. Well played Max.
Karbs
Date sent: 2018/08/09 19:09:56
bruh max why you responding like you some sort of customer support agent
Corney
Date sent: 2018/08/11 20:33:06
Karbs he needs to look official to pass t mod
Asriel🍆
Date sent: 2018/08/28 14:44:34
if only it were this easy for me
