Be able to choose your custom render distance
ImTyeDye
Date sent: 2018/10/31 21:22:13
Right now, as I see we are forced to have a rendering distance of 12. This is one of the few bad things I see about this server. My laptop isn't that good, so a lower rendering distance would be better for me. Other players even wish to go up to the max rendering distance, but are forced to stay on 12. I had to stop playing mainly for the reason that my laptop kept overheating every 5 minutes I was on, but I fixed that with adding more ram and different CPU power settings. Although this doesn't affect me as much anymore, I still know that some players are put off to the server because of this feature, and I would wish to see it changed.
Date sent: 2018/11/01 00:32:26
I thought that the server view distance was only a maximum setting, if the client has a lower setting than this it should discard excess chunks sent by the server.
Gavin
Date sent: 2018/12/12 14:11:12
you can lower it, the server has a max render distance of 12 by default.
ImTyeDye
Date sent: 2020/08/24 23:43:30
