alpacafarm |
Date sent: 2023/01/03 03:56:16
Username: alpacafarmWhy you were banned: X-ray When you were banned: Jan 2 2022 I never x-rayed so I'm pretty confused about this. I haven't been mining in a while, and when I did, I didn't have much luck. I'm pretty sure I don't even have diamonds in my chest because I barely had any, so I'm pretty confused as to why i am being accused on x-ray. I literally still use iron tools and I don't even have full diamond armor, and im pretty sure if I was xraying, I would at least have all diamonds and netherite gear. I'm not sure if my tunnels are too random, but I'm literally just strip mine. Anyways, i really just want to get back to playing as normal and I feel like this ban is not correct. I have been trying to have good behavior since I was muted and this is definitely not a reflection of the behavior I have been exhibiting. |
Spyro0104 the second |
Date sent: 2023/01/03 04:06:37
alpacafarm |
Date sent: 2023/01/04 02:48:56
BUMP |
Eliza |
Date sent: 2023/01/04 17:42:21
Hey paca. So, the xray happened before you got muted and dating back more than 20 days. You indeed havent mined in a while, but when you did mine, you xrayed, both diamonds and netherite. The diamond mining was disguised under ''strip mining'' in some occasions, the netherite not as much. |
alpacafarm |
Date sent: 2023/01/04 18:18:25
Thanks for letting me know, but I did not use xray. When I mine for netherite, I literally make a 3x3 tunnel because with an efficiency pickaxe, netherack breaks almost instantaneously. I changed directions every so often, which does not mean im xraying. I literally just stopped when I run into quartz/gold/anicent debris. Once again, I think i own like 2 netherite tools and thats it. If i was xraying, I think I would have much more than that. I hope this explains it, I would not use xray considering I have been on this server for 7 years and know that they are able to look at tunnels of people who xray. |
Eliza |
Date sent: 2023/01/04 18:26:41
The amount of tools you have has nothing to do with it, tbh. Plus your faction uses all the same chests which could totally mean you all share the xrayed stuff.''I haven't been mining in a while, and when I did, I didn't have much luck." You kind of dug yourself a hole with this statement. Looking at your supposedly random tunnels, you run into ancient debris/diamonds TOO often too consider yourself unlucky. |
alpacafarm |
Date sent: 2023/01/04 18:27:25
Regardless, I am apologize for my previous offenses and if I get unbanned, I will be a positive member for the community and not be toxic. Pls unban im sorry |
alpacafarm |
Date sent: 2023/01/04 18:28:48
I would still say I didnt have much luck, I swear I did not xray. I dont even think they have xray for macbooks. Just because I found some diamonds doesnt mean thats good luck. |
Eliza |
Date sent: 2023/01/04 23:12:35
Here's some proof.Example 1 1) You dug straight for some time and stopped, then went a bit back, broke that big batch in the middle. Then at a later time you came back and dug in the wall randomly and found diamonds inside. Example 2 2 You were mining a 2x1 tunnel for a while. At a later time, you came back and decided to mine to the side of it and uncovered some diamonds that would have been hidden behind deepslate in the og 2x1 tunnel. Example 3 3) Similar to the previous one, you were digging a 3x1 tunnel and came back later to dig higher up to uncover some, otherwise, hidden diamonds. Example 4 4) This tunnel was an old one, you came back, bridged above the lava and mined above you to uncover diamonds hidden by deepslate. Example 5 5) This is a combo of 3 instances that were too close to eachother to not merge them in one video. Once again, a 2x1 tunnel that kept going for a while, and you suddenly decided to go up a couple blocks, to find the diamonds to the right. You kept going, exited the tunnel to a cave and went left, and in a very lucky(?) way mined straight up into the ceiling to uncover a few more diamonds Kept going straight on that tunnel but opposite side of the cave, got some gold and diamonds below at a later time Let me know if you have any questions. |
